Yukon Denali XL (2011) - Radiator Replacement - Oil Cooler Line Issue
MWD_CTSV
Your oil lines look a little worn or possibly out of round. If there is a ridge at the edge of that shiny section, it may damage the seals unless you can scotchbrite it smooth.
The fit is pretty tite, but if the pipe is round it should fit. Maybe the OSC fitting is too tight, but that is solvable with the factory fitting as suggested.
Edit: Sorry forgot to zero the calipers, but the delta is accurate. It is .030-.040" clearance.
MWD_CTSV
And for the taper, I see .6530" ID on the fitting and for the OD on the pipe, it is ~.6485 +/- .0005. So even more clearance for the taper.
I do not know the torque off-hand I wouldn't attempt anything over 20lbs and probably stay under that, snug should be fine
maybe @swathdiver has that info
18 foot pounds!
This is why the manual says to use the Jiffy-Tite tools and not pop the clips out and lose or break them.
Just gotta wiggle them around as you force them in and they ought to snap right into place.
MWD_CTSV
Here are some pictures of the fitting. In the first one you can see the taper on the fitting is not pushing through:
It looks to me like the taper high point is fully past the chamfered edge, so it isn't binding on the taper. However, it is possible that the slot cutout for the clip has a large burr which is catching on the taper, but the side shot closeup shows the back edge of the cutout and it looks very clean.
Also, seeing that the fitting has a tamper detection mark, I don't think it is a good idea to remove it. Probably better to measure the pipe and fittings first to check the clearance and clean the pipe to remove any small ridges, before voiding the warranty.
T
Tahoescostalot
MWD_CTSV - thanks for posting those pics! Will try and scotchbrite the fitting and see if that helps solve my issue (option 1).
(option 2) I couldn't find the oil cooler fitting for my model. Anyone have a part number i can search for? Also, does this replace the large hex washer on the radiator?
(option 3) If I end up replacing the radiator again, any recommendations for another brand?
swathdiver - thanks for the help!
T
Tahoescostalot
On the replacement oil fitting, does the large metal shroud need to be removed first?
What's currently on radiator:
MWD_CTSV
First I would check that the new fitting fits the oil line.
Second, I am a little concerned that you don't have an OSC radiator. OSC claims to use the same plate cooler as stock, and that cooler and fitting don't look like the pictures from OSC.
Gdub
