CJ Rodarme
35s max for now, probably used ones at that
Yeah of course, but what size tire do you think is going on a 20 x FOURTEEN INCH WIDE wheel? Why would he run 33s on a 20 x 14" wheel with a 6" lift? Then were talking about width. A 14" wheel is going to stick out past the fender, what, 4 or 5 inches? Then more for the tire. Its not just weight, its also contact patch. Aerodynamics are going to be hurt with those wheels and lift. Then lets consider why they want to put this on, plus they are spending on other mods. Re-gearing is a logical piece to this overall setup, unless the OP either doesn't care about losing acceleration or is some how adding 100+ ft lbs tq so it doesn't become a slug.The tire is gonna determine whether or not he needs to regear. If he's gonna run 33's it's not gonna matter much at all. plenty of people run stock gears on lifted trucks. It's not like he's gonna stuff 44's under it, 6" is a pretty mild and common lift.
Gramps? Calm down? You're the fool trying to ignorantly make an argument out of your own assumption, and a single example. Then act like its expected because "fury did it". OP has already said they were not doing that...Idk, fury’s 33x14.5 seems to be pretty popular now. People are running low pro’s on wide wheels. 14 isn’t super wide anymore, calm down gramps.
His choice to make, you don’t need to re gear for 35’s. Go read truck forums, most of those guys run 35’s or 33’s on stock gears.
