ugadawgs311 said:
Just got done reading your posts about your install. Wow... excellent stuff. Thanks so much for all the info and pictures, it really helps. I'm planning on putting a X920BT into my 2007 Tahoe so I assume it will be a pretty similar install to yours. I have almost all identical harnesses. I have a couple questions if you get a chance to answer them:
1) On the GMRVD there are two grey connectors (a male and female). What do these plug into?
2) I have the PAC SWC-PS and an Axxess SWC that automatically programs itself. Which would you recommend using?
3) There is a green/white wire coming off of the PAC OS-4 that controls Onstar volume. What did you plug that wire into?
4) Did you cut the brown mute wire off of the PAC OS-4? If so, what did you hook it up to? I want to perform the bypass; will cutting the brown wire interfere with that?
5) How in the world did you get all the wires/harnesses to fit?!
Again, incredible job. Thanks so much for the help you've already provided!
ugadawg?? Man I am a tnvol...
I live here in GA so I will help you anyway
Seriously, you should probably ask these questions in the thread, someone else might have the same questions.
1)Match the connectors that went to the OEM HU by color. The grey will actually fit the brown but that is not correct. One end of the GMRVD hung free in my install since the OEM is no longer there. It is really just a breakout cable in this application. I tucked the free end down and to the right looking into the hole for the HU. I originally was not going to cut the lower horizontal plastic piece but had to in order have space for all the cables.
2)I used the SWIPS because there is a direct connector on the OS4. The SWIPS is a bit of a pain to program but once you have it, you have it. Looked like the Axxess unit would have to be custom wired.
3)Can't remember on the green/white wire. Let me think about that one and get back.
4)I cut the brown wire and connected to the mute in on the z120bt. You have to use the mute out end of the cut OS4 brown wire. If you don't cut it, the OS4 will turn off the HU when when a call comes in.
5)As above, I had to cut some extra plastic at the bottom of the HU well and tucked the cables back into the recesses at the bottom left and right under the HU. It is tight but they fit. I put the SWIPS at the bottom of HU well below where the climate controls are.
