My install - Pioneer DD & Headrest & iPad
aflumb
Las Vegas
Nathan would u happen to know the wiring u used to go from ur ipad to ur head unit
NathanJax
NathanJax
Vacation Nathan
Administrator
Jax, Fl
I used the Pioneer iPod cable. for the 8400 i have the CD-IU201S and for the 4400 i used the CD-IU201V
aflumb
Las Vegas
Ok kook. The reason I ask is I have the Pioneer cable that I use for the IPod. But when I hook it to my Ipad it will play for a sec then the Ipad say acc. Not req.
NathanJax
NathanJax
Vacation Nathan
Administrator
Jax, Fl
hmmm... never had that happen.
aflumb
Las Vegas
Yea. I think I'm just gonna order the Apple AV cable so I don't have to worry about it being wrong. Also when u installed ur head rest where did u get your ign power source from? Sorry for all the questions. Just wanna make sure I do my stuff right. Again thanks for all the help
NathanJax
NathanJax
Vacation Nathan
Administrator
Jax, Fl
From the same harness as the radio. Just ran a couple wires back there. since I ran the headrest to/from the radio. My headrest can play their own thing, or they can play from the output of the radio.
:Handshake:
shundal
NorCal
:Handshake:
Did you tap into the remote turn on lead of the Deck for the power? I need to wire my istreamer to a switched cigarette lighter and wanted to use remote turn on from the deck to power the istreamer. Do you think there is a need for a relay if running multiple amps and an accessory off the remote turn on? I know there is switched power near the drivers side kickpanel, but it would make it much easier to just go off the radio.
NathanJax
NathanJax
Vacation Nathan
Administrator
Jax, Fl
If running multiple accessories, I would run a relay.
shundal
NorCal
Thanks. I ordered a relay yesterday just in case. Right now I'm running 2 amps off the remote turn on. The istreamer will be the only accessory i'm running, but it's probably better to be on the safe side.
Low Beam
