Jhwhite05
- Joined
- Sep 17, 2021
- Posts
- 41
- Reaction score
- 73
Hahahaha! I’m still here. Just got sick and out for the count until this thing passes.
Hope you feel better soon! There's definitely some crud going around. My son has been home sick with a 102º fever for the last 2 days.Hahahaha! I’m still here. Just got sick and out for the count until this thing passes.
Yeah, totally. My wife got a flu-thing and it lasted 2 weeks! Crazy. I’ve got a lighter version, so I’m planning on bouncing back asap!Hope you feel better soon! There's definitely some crud going around. My son has been home sick with a 102º fever for the last 2 days.
It is a known issue that LED tail lights will disable your cruise on certain models, I'm not sure if the 900s were affected by this. The system checks for resistance at the tail lights and with LEDs having much lower pull, the system thinks your brake lights are out and therefore won't engage cruise. The fix is typically resistors at both brake lights.
In your case I would start with the fuse, then check your steering wheel switch and brake light switch. Here is a video regarding the brake light switch issue:
Mine would work fine in the daytime but not at night when my taillights were on. You might check to see if it works in the daytime.It is a known issue that LED tail lights will disable your cruise on certain models, I'm not sure if the 900s were affected by this. The system checks for resistance at the tail lights and with LEDs having much lower pull, the system thinks your brake lights are out and therefore won't engage cruise. The fix is typically resistors at both brake lights.
