P0641 after during oil pump Install
Charles Hughes
2007 GMC Yukon Denali 6.2
So I attempted to install a new oil pump but was interrupted half way and had to stop. I removed the water pump. I removed the power steering pump rack assembly (5 bolts) and pushed it off to the side. I used a factory gm puller and tried with that along with O'Reillys puller and when I had to stop I just reassembled and figured I would do it next week.
I don't know what happened in the short time I removed those few items but now when I start I get P0641. I did use a small map gas torch on the crank bolt. No wiring seems to be bad. There is the one plug behind the bolt and that 6pin one or whatever it is on the bottom of it. I checked the wire harness's including the harness that usually rubs and causes it over the coil packs. Anyone have any ideas while im on a break or have any clue what might have been messed up? I checked the plug for the maf as well as the map sensor. It will try to start. Sometimes backfires but that's about it, throttle plate on the throttle body will twitch but not move alot but assuming that is caused by the bigger problem. If I try to crank it I do have fuel at the fuel rail if I press the fuel valve so assuming I have a working fuel pump although fuel level recently has been reading incorrectly sometimes. Open to ideas
C
Charles Hughes
I did try to start it without the serpentine belt on to eliminate that possibility.
BG1988
you forgot to plug in a sensor
The sensor in question is typically associated with the automatic transmission, transfer case, or one of the differentials.
j91z28d1
I'm not in front of a computer. what is code P0641?
strutaeng
Dallas, Texas
P0641 code: Sensor Reference Voltage "A" Circuit/Open
So basically a wiring issue, it seems?
j91z28d1
ahh yes. there's a bit about that here.
wiring somewhere. check for voltage on that pin at the ecm and then bounce around thru all the plugs on the circuit until you find one missing the 5v reference voltage
k09viper
