Weather strip under chrome replacement
Ruikee
2015 Tahoe LT 4WD
Starting to notice this rubber strip is coming out from under 2 of my windows. Can/how do you replace it? Will it cause any problems if not replaced?
Blackcar
You might be able to put silicone grease on rubber and try to work it back under molding with plastic pry tool to keep from scratching paint.
I wonder what is causing that do you have vehicle washed at auto car washes.
R
Ruikee
Yes, i do wash at car washes. Two other windows are doing it now. It does go back under easily but then comes back out. Is it a part of the chrome molding? How does it come off if so...
Blackcar
I know this link is for pickup but same idea for Tahoe look for the screw on trim.
I think maybe the air blowing on drying cycle is blowing rubber out maybe.
6Parkers
bringing this back from the dead since I found this question already being asked. I don't take my through car washes and my yukon is doing this on 3 of the windows. I have searched high and low for a solution or part # I wondered too if this rubber piece was part of the chrome or not? Did you ever get yours fixed/replaced?
packle
