Cluster, Radio, HVAC LED Swap Polarity Info.
grnphrog
I needed the same info and was excited to find this, but I'm stumped now... This diagram shows the solder points being next to each other (Left to Right, East to West, what ever orientation you want to use) but my radio has them being North/South (Up/Down, Top/Bottom) orientation.
With that being said... I found some LED's with the resistor 'built in'. Anyone heard of that before?
Here is the ebay link: http://www.ebay.com/itm/111855442605?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Mezzo
If you manage to figure out the diagram for the heated seat controls for 03-06 I would be so happy,thats the only one one i havent figured out yet
toddis32
Wi
I've been told you mount 1 LED in one direction and the next LED is mounted the opposite way. So alternate them.
toddis32
Wi
You can get the 12 volt cubes with built in resistors in 3mm cubes here: https://www.ebay.com/str/gmgaugerepair/12-volt-LED-Bulk-Sales-3-mm/_i.html?_storecat=23349650017
The 5mm for the speedo are here: https://www.ebay.com/str/gmgaugerepair/12-volt-LED-Bulk-Sales-5-mm/_i.html?_storecat=23349651017
The previous link is not working any more.
Silentnight008
