Fosscore's 2013 Suburban LTZ Build Thread
Fosscore
Fosscore
@kwOH
Dorman replacement was $28 Amazon Prime when I ordered it.
Here is a pic with the door panel removed.
Replacement is pretty easy. Follow this video. A few bolts, the panel plastic clips, water shield and unhooking the lock rod. 2nd time was faster.
kwOH
Banned
@kwOH
No disappointment in the quality of the dorman? Found some on eBay but they dont say if they are dorman brand. Probably order off Amazon as well so i can make sure i get the dorman brand, and thats the exact video i found last night, love 1aauto's videos lol. Good lookin out on the info man, the crew cab needs both front handles.
Sent from iPhone 7 plus using Tapatalk Pro
Fosscore
Fosscore
Dorman or I have seen a Depo one I think. They are all plastic and pot metal unfortunately. Even the OEM is just what it is. Chrome plastic.
Their videos have helped me numerous times.
Pretty easy overall. The body panel clips were tight and getting your hand to detach the lock rod was a bit tight as well.
MichaelSE
2010 2500
Tucson
Hey Fosscore, since we both have Cashmere leather, what would you do to clean and condition this? I've tried Poorboys leather cleaner and more recently Meguiars. They seem to condition well but don't clean that well as you can see from the grime still in the creases. That's after scrubbing with a microfiber sponge. IMG_8621.JPG
Fosscore
Fosscore
Those creases are a PITA as are the perforated seats (but nice when they are cooling your nether regions on a long road trip or Florida hot day). Sometimes the crease is just a wear spot in the leather and not necessarily dirt. It may not come out if it is already worn out from use.
When nothing else (product of your choice or elbow grease with cotton rag or microfiber is working), then you might have to resort to less traditional methods to get back to square one.
I will usually pull out the Magic Eraser if I am meeting with resistance. I know some guys will say no way, the chemicals and abrasive nature of the sponge on the leather, but it does work. I have used it on the 06 and the 13 leather seats with great results and plenty of clean interior compliments.
Pick a test spot, make sure the Eraser is wet, but not dripping wet and gently work that area and wipe clean. A brand new Eraser will yield very quick results. You can still use your leather cleaner along with the Eraser for lubrication and cleaning purposes. You want to go slow and easy so that you don't strip the sheen off. If you go hard core, you will clean the seat and it will be a matte finish upon completion.
If you like how this is working, then go a bit further wiping as you go to compare and see if you missed anything. I wipe the leather down once again with a cleaner and microfiber before moisturizing it with your favorite leather treatment. This is a key step at the conclusion to condition the leather since you are mildly stripping the natural oils out.
Some guys on TYF and many other forums recommend Magic Bubbles as well. I have not personally used this recipe, but it is another option to help clean really ground in dirt, again going lightly, cleaning and moisturizing.
Go slow, do a test spot, clean again and moisturize. That should do the trick. Hope that helps a bit.
@MichaelSE
08HoeCD
Hey Fosscore, since we both have Cashmere leather, what would you do to clean and condition this? I've tried Poorboys leather cleaner and more recently Meguiars. They seem to condition well but don't clean that well as you can see from the grime still in the creases. That's after scrubbing with a microfiber sponge. View attachment 180963
Google LVP Refinisher
Some on here have used it with astonishing results, making creased and cracking seats look virtually new.
MichaelSE
2010 2500
Tucson
Awesome, thanks so much for the replies. I have heard of people using magic erasers on leather, but I was hesitant for the same reason you mentioned - the abrasiveness of it. But if you've done it with success I'll give it a try. Sorry for temporarily getting off topic, now you can get back to posting pics of your Escalade-tier Suburban :D
NJ04HOE
Paterson, NJ
Austin12
