The Khan - 2005 Yukon Slt buiild
SteveB
SteveB
Got a new head unit in it yesterday.
SteveB
SteveB
What'cha get?
Just a cheap no name unit , there is no name anywhere , bought it off a buddy who paid a 100 for it with the back up camera. I will be getting a better head unit when I can afford one. All I really need and care for are Bluetooth and back up camera.
All the guts are the same, no matter what name brand it is.
SteveB
SteveB
Well I don't know if the head unit , camera or the shifter is out of wack. When driving it wants to switch to the camera at random.
Think I also have a wiring problem for my cam senor , changed it and it still throws a code. I can delete code , Start the truck and the code is gone. Drive the it with no code coming back , shut it off , restart the tuck and the code is back.
SteveB
SteveB
Yes I wired it in the reverse light , pretty sure its a wiring problem cause when I cut the red wire on the camare pre-out it stops doing it. Yes the camera doesn't work when I do that.
Getting code po342.
Getting code po342.
Error Code P0342: Camshaft Position Sensor “A” Circuit Low Input
Error Code P0342 is defined as Camshaft Position Sensor “A” Circuit Low. This means the CMP (camshaft position) sensor circuit on engine bank 1 sends an irregular reading.
Weird.
Def sounds like a wiring issue. Wiring backup cams to a dd is pretty straight forward.
Jordan0277
