The Khan - 2005 Yukon Slt buiild
Did you go back to check your wiring on the camera? It only works while in reverse, correct? When putting everything back into the dash maybe a wire got pinched back there. Did you have to remove the large metal brace behind the dash?
SteveB
SteveB
That's why I think it's a wiring problem change the sensor and still get the code.
Yes wiring the camera was stupid easy. Tie the 2 red wires to the green reverse wire , black to black, then red to pink on the deck. I soldered my joints on the reverse light wires , then used spade connectors for the deck connections.
SteveB
SteveB
No need to remove the any brace , the head unit is very sallow. Can only play music and such from my phone , usb stick , or sd card. Only has fm radio. Tried running a separate wire from the reverse light to the head unit , same thing happened , never tried a different ground yet. Yes only works in reverse. It never shows any picture in drive when it tries to cut in , just a blue screen saying reversing.
adventurenali92
Big Bear Lake, ca
Just got caught up on your build! The led fogs look good! I don’t like amber fogs but that’s just my taste! Good work on color matching the bumper!
SteveB
SteveB
So looking to see what kind of led light I need for my puddle lights , I come across a thread where a guy sanded his puddle light lens smooth. So guess what happened....lol. Now I need to decide if I want blue or white light.
Ever figure out your backup cam issue?
I can't even get mine out without them cracking or breaking.
SteveB
SteveB
I haven't messed with the camera issue much.
Yeah getting the puddle lights out can be a pain. I found for mine , get the lock to release then work the other side of the lightly and it popped out.
Sam Harris
Texas
Yessir! I did that, after someone else too. Lol. It’s a nice little assist to more light output! [emoji16]
tinkersmithinc
