avalonandl
Troy, MICH & Naples, FL
Usually that happens when the sensor is dirty, clean off any dirt or mud off the sensor and between the sensor and body and off the body on the outside, the sensors are on the left & right side right behind and above the rear wheel well's. they are shaped sort of like a claymore.
Well thats going to have to wait until spring/summer....Not crawing underneath to check that with all this white crap and slush on the ground.
BTW = I think that it could be a bad sensor/connection because this started when all the running boards were removed.
They are flat 12 hours later.
yep that would be a leak and when you drive it around it leaks even faster, I noticed mine was having a problem because I could feel the difference while driving, it would air up and work fine when started but then go flat while driving turned out the air pump was leaking air out of the relief valve. that was on Arnott pump number #2 rockauto refunded me for it after the 2nd return and I bought the dorman and haven't had any issue, usually the arnott work fine but I guess I just had bad luck the 1st one stopped inflating properly.
Isn't some of that bamboo invasive? Just like that creeping ivy. Just takes over EVERYTHING!! @Just Fishing maybe plant some of that creeping ivy near the fence. That shit will take over once it gets established. I bet that would **** him off. Grows up the fence, up trees, up parked jeeps lol!!
ya that's why I said some of it grows crazy, lol there are different variety's. like weed.
CHOO CHOO
BackPagePhil
Manheim, Pa
Finally opened the catchcan..... This was after driving, but still..... It was like soft-serve ice cream..... Contemplating flushing it out to see if something is clogged. Just odd that is has not drained in the past two oil changes.PXL_20210219_172140264.jpg
Sent from my Pixel 3 using Tapatalk
Just Fishing
Can't fix stupid
Utah
actually we already have some of that.
Tried and failed with another neighbor to kill it once and for all. :jester:
So my property line is also weird, i'm in a cul-de-sac, and ****** lives around the corner from me.
My property spans about 5 different houses.
His direct property line to mine is a small section of fence, maybe 15-20 feet.
Then the neighbor right next to me in the cul-de-sac has this pizza slice shaped property.
the tip of the pizza goes right between the ****** and my yard.
so we have this nice little space between the majority of our yards, however his house still looks directly at the back/corner of my house.
So for the little section of fence, i don't see any vines really to speak of, but i can fix that with some work...
Got me thinking of a possible solution to the larger space, maybe a few posts and chicken wire will entice that vine to grow up higher...
Keep the ideas coming! :peace:
Jason in DLH
Cheeseburger and Fries
MN
Finally opened the catchcan..... This was after driving, but still..... It was like soft-serve ice cream..... Contemplating flushing it out to see if something is clogged. Just odd that is has not drained in the past two oil changes.View attachment 271299
Mmmm...chocolate ice cream...looks delicious!
Just Fishing
Can't fix stupid
Utah
loosing any antifreeze?
otherwise the can will catch condensation as it boils off.
Jason in DLH
MN
Just build a Trump wall...
CHOO CHOO
BackPagePhil
Manheim, Pa
Nope, everything was topped off a few months ago when I replaced the radiator. Still pretty much full.
I'm used to it draining a bit when I change the oil, that's why I was a little concerned. Probably nothing tbh, but I'll take a look when it gets warmer outside
St. Louis
Mine looks like that in the winter. When the condensation (water) mixes with the oil it turns thick and milky like that and drains slower
KodiMoe
