Well after trying to figure out my brake issue the front hub started making little noise today. Guess that could be the issue. Bought the moog hub and it lasted just over a year :confused:
Whats the better one thatll last more then a year atleast. delco, dorman or timkin?
take the moog back to wherever you bought it, should have a 3 year warranty
Should I loosen them a bit or just let it go?
Sent from my Pixel 3 using Tapatalk
You might want to loosen them so they don’t seize later. Just snug them up with a 3/8” ratchet.
Maybe I'll find someone to borrow them from, I just want to take the spacers out and drop the rear another inch. No need to buy them just to use them once
Sorry, I was thinking about a different type of spring clamp so disregard what I said about those being so cheap lol.
Just Fishing
Can't fix stupid
Utah
Engine is out of the hoe!
mounted it up on the engine stand, didn't have bolts that fit so i made some spacers out of tubing and used the power steering/alt mount ones.
yup, to0 long to turn the engine.
:Big Laugh:
i'll get some bolts during the week some time that actually fit.
And i pulled the lifters outta there, noticed some light grooves in the rollers, it catches my finger nail just slightly.
I think i'm replacing them...
I need to borrow those spring clamps....lol. you can rent those from the parts store correct?
Just buy a set, the ones I got were about $12-15 for 2 pairs that were slightly different from each other. They don’t loan them afaik.
I borrowed a set from O'Reilly and they started bending. Borrowed a similar set from AutoZone and used all four to distribute the load. It worked fine, but took twice as long setting up and having to turn four compressors a little at a time. It's a cramped mess of steel everywhere.
I have never seen a set that I can borrow from a auto parts store that I trust.
Here is what I got off of Amazon.
Shankly Spring Compressor Tool (2 Pieces) - Heavy Duty Build, Ultra Rugged Coil Spring Compressor, Strong and Durable Spring Compressor with Safety Gu https://www.amazon.com/dp/B071DQJG24/ref=cm_sw_r_cp_apip_yUWAnYSdKGPRJ
Word.
You don't need compressors to remove spacers in the rear. Unbolt the bottoms of the shocks, unbolt the bottoms of the sway bar end links, jack up the frame on one side until the coil is loose, remove spacer, lower that side making sure coil is seated properly, jack up and repeat for the other side, reattach end links and shock. Done. Just gotta watch the brake hose in the middle when jacking up the frame/body so you don't go too high. You shouldn't have to go very high with lowering springs, though.
Word.
Yeah I got confused on another thread where the convo was about my favorite kind of clamp (spring) for hoses and the pliers used to install and remove those. The last set of spring compressors I borrowed from an auto parts store almost killed me, years ago. My NNBS Silvy doesn’t have these contraptions yo. :cool:
05_200Ktahoe
