2005 Crown Victoria P71 Build
95escahoe
95escahoe
Got the Vic back last Friday got around to installing the Marauder tails and reverse light panel, I still might do the Marauder spoiler I know someone selling a complete trunk lid cheap just needs a repaint
95escahoe
95escahoe
Got around to installing the secure idle over the weekend, took a lil bit longer then I thought it would take to install mostly trying to find a good place to zip tie the box didn’t want it in there loose banging around, so I removed the knee brace and was able to find a hole in the dash brace and zip tie one end there and the other side around the steering shaft tube, it doesn’t rotate the steering shaft goes inside of this metal tube in this part of the dash it’s a common place to zip tie it, usually they just throw it up under the RH side of the dash but I wanted the button on the LH side of the dash so you can hit it with one hand and remove the key with the other
Sam Harris
Sorry, but I scrolled all the way to the beginning of the thread, to see the difference between the tails and reverse lights, bit don’t see a difference..! Do
you have a before / after, or other comparison?
95escahoe
95escahoe
The Marauder tails are lightly tinted compared to the Crown Vic tails and the reverse lights on a Marauder are smoked on a Crown Vic they are clear, here’s a pic of the factory lights from last year
Sam Harris
Ok thanks. Now I see it. [emoji106][emoji16]
Much better.
Mikegrz
