I have some copper braid but I didn't try it. I will next time.I don't think I've ever used anything to remove solder except copper braid. That's just how I was trained.
Did you have any polarity issues with the LEDs on the CC board? Just wondering if I need to test before I solder.
I have never heard of using sealer on an OEM gasket since it's rubber. I used some on my 08 that has an aluminum fuel cell and I had to make a cork gasket for it. I used Gasgacinch Gasket Sealer which is gas resistant. So far no evap leaks in about a year. Permatex makes one too, Aviation Form-A-gasket.Used a smoke machine on the evap system, found a leak near the fuel pump but couldn't tell exactly where. We lowered the tank a bit to be able to see things better but didn't have to disconnect any lines. Thought it might be the fuel tank pressure sensor but we put some air to the system and the pump gasket is leaking. It was new almost two years ago with the AC Delco Pro pump, so kind of a mystery as to why now. Have to check on a warranty replacement but even without that it shouldn't be bad for cost. Just the hassle of dropping the tank and swapping out the gasket. Wonder if anyone uses any kind of sealer on the gaskets?
Here pics of the Esky crossbars off my 02. Hope it helps.I am looking at cross bars for the roof rack on the esky. Do these look like the right style?
00-06 Chevy Tahoe Z71 Roof Luggage Rack Cross Bars pair 02 03 05 2004 Z71 only | eBay
Pair of roof rack cross bars for 2000-2006 Tahoe Suburban Z71 models only. In good used condition with average wear.www.ebay.com
These are listed for NNBS but appear the same.
07-14 ESCALADE YUKON DENALI ROOF RACK ROOFRACK LUGGAGE CROSS BARS OEM 15748100 | eBay
Find many great new & used options and get the best deals for 07-14 ESCALADE YUKON DENALI ROOF RACK ROOFRACK LUGGAGE CROSS BARS OEM 15748100 at the best online prices at eBay! Free shipping for many products!www.ebay.com
Wife booked us for camping in a few weeks and I've got to find a way to get the old thule cargo carrier up on the roof.
On the pissed about money spent side, needed a replacement regardless as the original was damaged & didn’t want to buy stock again.Cut the magnaflow out and install a different muffler or just pissed about money spent already?
Fuel pump seal@915_Tahoe when you have a chance, would you please look up a fuel pump gasket (tank seal) and pricing for me?
It's for my '04 Tahoe, 5.3 Flex Fuel, last 8 of VIN 4R199261.
I see a couple of numbers online so I'm a little confused about what's the correct one. G52 (19337980) and G39 (15103734). If G52 is correct, does it supersede G39?
Thanks, I appreciate it!
