Looks great! What is the process like for applying the Cerakote.
I washed the parts with blue Dawn, rinsed and let them dry thoroughly and then wiped with denatured alcohol and a dry cloth. You have to wear rubber gloves when applying the Cerakote. Also, you need to work fairly quickly because it starts to dry after awhile. The most important thing is make sure there's no water present or it will be splotchy.
02Z71Raven
I am Dewalt fan but I been cheating on the brand after I bought a Milwaukee setup during Christmas at home depot. Now I have a 3/8 drive Milwaukee ratchet and the 1/2 impact gun, both in non fuel and I love them both!! I'm sure the fuel models have more to offer but I don't need them. My air tools are easily available in the other drawers. I was pleased with the performance on the Milwaukee 1/2 impact gun. Removed my wheels lugs easily with no issues
Yeah, I have nothing bad to say about Milwaukee. I'd take either one based off price. They're both great tool manufacturers.
Logan5
Albany, NY
Here's a bunch of mods I've done over the last month or 3.
Front-side window tint. Local tint shot wanted $180 to do the front sides. I ended up getting some pre-cut tint off Amazon for $40 and installed it myself. Came out great.
Under hood LED lighting with a manual switch. I don't care for the hood-actuated switches.
Transmission cooler. Tru-cool 40k.
LED bulbs all around, and here is the load resistor to prevent hyper-flash.
02Z71Raven
View attachment 348274View attachment 348275
Looks like you spaced it off the surface. You'll get better heat dissipation if you mount it flush on the metal surface. Just a tip, not necessary, but the resistor may last longer.
Logan5
Albany, NY
Yeah I mounted them flush to a metal surface in the front, but in the back that's the plastic taillight housing and I spaced it to prevent it from melting the plastic.
I really like what you did with the underhood lightning. It's different. Did you use Eagle Eyes?
I wouldn't worry, it's fine since the whole thing is wrapped in a heatsink unlike the regular wire-wound resistors that are sometimes used.
Stevemo70
