The only thing I have to add is don’t forget sealant on those rocker bolts.
Good work Dan.
is he not going to put rtv on the rocker bolts?The only thing I have to add is don’t forget sealant on those rocker bolts.Good work Dan.
I was being fastidious but in any case I’d use a high temp thread sealant like Permatex 59235.is he not going to put rtv on the rocker bolts?
just drill them front ***** out, its just the water jacket 90% of the shavings are gonna be on the outside anyway. the last couple will just get caught in the radiator
I just bought a big tube of that stuff and freaking love it! I wasn't sure if I should use it or ultra black RTV since it will sorta have direct oil contact.I was being fastidious but in any case I’d use a high temp thread sealant like Permatex 59235.
Pretty sure I slung some standard ol RTV in mineShould be pretty easy and foolproof, just stop as soon as I feel it break into the water jacket right? Worst case scenario I tab a little doodaa on it with my tig machine.
And your Bitches*The only thing standard I like is transmissions![]()
The Permatex should work fine too, it says it resists diesel fuel and hydraulic fluids. I know from experience that RTV dissolves in gasoline for sure.
Permatex® High Temperature Thread Sealant, 50 ML - Permatex®
www.permatex.com
Ain't nothing standard about @randeezAnd your Bitches*
Have you had your hands on his stick shift again ?Good info, black rRTVtv never seemed all that tough to me but even my LSX engine bulding book said to use black rtv so thats what I used before, I don't like how RTV doesn't stick into the threads as that Permatex stuff does. I'll use that Permatex stuff for sure now!
Ain't nothing standard about @randeez.
