2004 6.0 NV4500 Tahoe
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I did not thoroughly clean the heads from the machine shop because they came in a vacuum seal bags and appeared to be spotless when I unpacked them. Is it possible that they were full of CNC shavings?
You can’t use the hat style valve seals with dual springs. You just found out why. That’s why I asked earlier if you bought Viton seals. You need this style. The hats on the ones you installed interfere with the inner spring on a dual spring setup.
You should have received different seats that came with the springs, then the style seals I showed you. The seats and seals are 2 piece instead of the 1-piece seat and seal. I know when I bought my springs from VHP, Roger made sure I had the seats and seals that worked with them and told me the reason. Where did you buy your springs from?
ElMasBuscado23
