Fan only works on high
OmarR
Indianapolis, IN
I would first check to make sure you didn't get a bad "new" resistor. Did you buy new, or pulled from a salvage yard?
After that, I would suspect the head control unit.
As JK mentioned, there are 2 fuses:
High Speed - 40A blower fuse under the hood
All other speeds - 30A Heater/AC fuse in the driver side fuse panel
The only problem is that even though the high speed has it's own fuse, the 30A Heater/AC fuse is still a part of the equation, so if either (or both) fuses are blown, the high speed will not work.
Since your high speed is working correctly, I would verify your new resistor (can you exchange it for another?) and then change out the head control unit. Ebay.
Badluck
Badluck
SE WI
I bought the new resistor from ebay from an ex-gm dealership inventory. I'll recheck the fuses also.
Badluck
Badluck
SE WI
It was a faulty new resistor. I bought a new control panel from ebay anyway since the left side lights of mine were burnt out. Thanks for the help.
dwmmatt23
central valley cali
+1 I have just bought a Tahoe -01 LT and there is no air speed on 1-3 only on 4 and 5. Where are these fuses located and where are the alternators?
Im a total noob when it comes to these cars, have had mine for 1day.
my 02 tahoe only works on 3 and up
Badluck
Badluck
SE WI
Get yourself the blower motor resistor. They are about $40 on ebay, $50 parts store.
Badluck
Badluck
SE WI
I believe there is a separate resistor for the rear.
Ispa805
