makintoshnex
- Joined
- Sep 30, 2023
- Posts
- 146
- Reaction score
- 73
I think you're right sir. Well, I didn't have the match of a chance to drive on that wrong gear ratio differential. And the guys from the AAMCO they said that my tranny and gearbox are fine so I don't really worry about. Probably yes, I have that thing with the solenoid because there is a taking clicking sound when you accelerate and decelerate. Unfortunately here in Brooklyn New York we don't have a good mechanics. For instance, I had the issue with Stabilitrack. I went to the shop for the diagnosed. They said I had to replace the whole ABS system. It's going to cost me $2,000. For you to know this is a very good shop with very good reputation and that mechanic took me basically behind the counter escaping the whole line of cars he had. He did me a favor. In order to just apply for a simple inspection for the shop, you have to stay in line for 30 or 40 days. I solved the problem just by a hammer. I had a bad terminals on the positive and negative so I just hammer them down and tighten the screw as much as they could and that's it. No more stability track issue.wow that sucks they put the wrong ratio gears in.. that sounds like it would be very ******* the transfer case as well of you drove around in auto setting. in 2wd it might not have been horrible.
as for the missfire. I don't know how much you work on cars, but for the missfires treat it as if it's a normal truck. normally you start with a tune up, check the grounds, there's one on the front of the driver's cyl head that's common issue in all ls engines. also these hybrids have quick release battery terminals.. make. sure they are tight. you shouldn't be able to move them at all by hand when tight. if you can track down which cyl it is that throws the code all the time that is helpful. sadly on all these trucks the afm is worth checking out, of that checks out. then switch coils around to see if the miss fire follows it to the new cyl.
I would agree that a tranny shop is probably not the best place to troubleshoot the engine in general.
honestly the dealer is a crap shoot too. they don't know anything special about these trucks, there's a huge turn over of techs at dealers and they haven't gotten any training on these trucks since probably 2008. and even then they are mostly parts swappers and these trucks need trouble shooters. especially if it's hybrid related stuff. like the afm can't be repaired bit dealers and most shops want to sell you can engine because it's eaiser and more profits for the.
just saying the word hybrid scares most parts swapper techs. so you'll probably be better off finding a smaller shop that isn't scare to work on it and has experience with finding miss fires on ls engines to see if it's ignition related or if it's afm.
these trucks really reward diy mechanics able to work on their own stuff, but if your have to rely on a shop. they will probably bleed your wallet dry and leave you with a still broken truck.
that's a pretty common thread on these boards. dealer swaps a bunch of expensive parts, it's something completely different and the owner ends up trading it off for scrap prices 6 months later. it's a shame really.
If there is someone on this forum for Brooklyn, New York or New York who knows a good mechanic who really I mean really can solve the issue not just taking money and tighten the bolt or something. Please let me know.
