Bigburb3500
- Joined
- Jun 7, 2024
- Posts
- 426
- Reaction score
- 741
Thank you for rewriting this, I TOTALLY understand how you are looking at it now. For some reason it did not “click” the first time I read it.The Chevrolet towing document I referenced - gave a GCWR for the 2017 Suburban as being 14,000 pounds. Your 3500 Suburban has a GVWR of 11,000 pounds - ergo ..... what's leftover from that 14,000 lb GCWR - is 3000 pounds - which is how you end up with the 3000 pound FACTORY tow rating for your 3500.
Basically it sounds like GM punted on coming up with an actual tow rating for the 3500 Suburban - likely because whatever spec came down from .gov for what they needed out of a Suburban that can be up-armored - had no requirements for an actual tow rating. So - as 15Burban said: they likely didn't bother running the tow rating tests and since the "regular" Suburban is already certified to have the 14,000 lb GCWR - and the 3500 Suburban has a rated 11,000 lb GVWR - you've got 3000 pounds of extra capacity to do something with - so they just throw that under tow rating.
Honestly I think people are taking the factory ratings on the 3500 too "seriously". Like I said before - look at the components used in the truck and look at what they're rated for in other trucks the very same components get used in - by going thru that you can come up with a realistic rating of what the 3500 is going to be capable of towing.
For example: (from the GM brochure for 2010 Silverado)
L96 6.0L engine with 4.10 gearing in a 2010 Silverado 3500HD SRW Crew Cab 2WD with 8ft box: Max trailer weight 12,200 lbs
2003 Suburban with the 8.1L gas V8 and a 4.10 rear end ratio tow rating is 12,000 pounds.
Now you've got a FACTORY rated tow rating on the exact same drivetrain that is your truck of 12,200 pounds , and a FACTORY tow rating for pretty much the exact same frame that is in your truck of 12,000 pounds - ergo - your truck should have a realistic tow capability of right around 12,000 pounds.
Cheers!
