Coolant leak behind crankshaft pulley
InspectahDEck
I have (another) coolant leak I'm tackling. After rinsing the underside from all the coolant sprayed everywhere, I tracked down the leak from the area in the image attached. Everything above that point is dry. Is this leak a symptom of a cracked head or possibly an intake manifold gasket? Any assistance is greatly appreciated
strutaeng
Dallas, Texas
Agree with @89Suburban
The intake is dry; no coolant passes through the intake.
I once had a leaking water pump that gave me a hard time. I replaced the gaskets where it bolts to the block, and the leak got worse. I was finally able to use an inspection mirror to see it was leaking right under the pulley of the pump. I had reinstalled the pump twice by then.
elianymanol
