SirReal63
I did most of the work on the passenger door. It has been clayed, cleaned, sanded, cleaned, painted and cleared. The SprayMax is such a great product, minimal orange peel and the nozzle is just about perfect for a spray can.
The passenger door with the first coat of paint and nib found.
I am going to re-sand this mirror, it doesn't show in this pic but it has a lot of spider cracking, the same as the driver side.
Nib gone and second coat of paint.
First dusting of clear.
First and second coat of clear. I will need to wet sand and buff this to remove the nibs and orange peel.
I believe this was the final coat of clear. I have a very nice thickness of clear. Not shown was the splatter mess after the first coat. My arthritic trigger finger was hurting so I used one of those spray paint guns and did not realize the can would rotate from the angle on the nozzle and the spray hit the edge of the gun and splattered. I let it dry about 7 hours and sanded it out, then continued with the clear.
I was concerned about the old hood matching the new door as this car has a multitude of shades on it. This morning after the clear had overnight to "cure" I buffed a section of the hood to see if I was going to have to paint the hood as well. I don't believe I will have to, the color is pretty much spot on. The lights and reflections shows a slight variation but with the eye none is seen. (ignore the reflection, I typically do not wear a shirt in the shop and yes, I need to exercise more.)
Pretty close, it will help once I am able to polish the door.
The four corners, the top and bottom of the door, the skirt and the hood. Only the hood wasn't wasn't painted. It looks off but it is a trick of the light and reflection.
You can easily spot the orange peel on the door but not much on the hood. Prior to buffing this small section of hood, the color wasn't very close. After a dose of 105 and 205 and a polishing cream it is going to be just fine. Now I will have to do the rest of the hood.
I got the driver door sanded down most of the way and corrected the rear view mirrors. I am waiting on sanding supplies. I have 2 cans of paint left but am going to have to repaint both bumpers and the entire back of the car so I am going to order more and make sure to have some left over.
