07 4L60E trans question
NickTransmissions
Sin City
The transmission bench
Unfortunately, I do not have a scan tool.
Id invest in one. Autel is prob the best bang for your buck and should give you all the capabilities you need as a DYIer. Not having a scan tool puts you at a huge disadvantage; they typically pay for themselves in one to three uses vs going to a shop to have them use their scanners and charging you $$$ for that service.
You need to find out if the PCM is commanding the TC off or if the TCC is releasing when it shouldnt be. If the TCC duty cycle is at or near max in third or fourth gear while cruising and slip speeds are higher than 10-15 rpm then there's def a problem. From there, you need to find the source of the problem.
The list of suspects are the following:
- TCC solenoid/harness (you replaced this - what tcc solenoid did you buy?)
- Worn TCC regulator valve (valve body) - very common in these transmissions
- Worn TCC apply valve (pump) - less common but i see it from time to time on the vac tester
- worn 2-4 band
- worn/failing 3-4 clutch pack
- Worn torque converter clutch and/or failing torque converter
Given the amount of miles on your trans, I'd begin saving for a rebuild if you havent already done so.
Are you open to learning how to rebuild it yourself?
992dr
992dr
Eastern N.C.
Fti is supposed to be quality stuff I’ve got a 4wd 4l60 with 175k miles I’ll let you get cheap but you would have to pull it out I could help you do that if need be but it sounds like something else maybe electrical in the computer or the sensors that’s a weird issue.
I always had Jamie Parker in havelock to tune my stuff and he has always had the transmission tuned dialed in perfectly but your right nobody around us wants to mess with transmissions there is one fella in James city Newbern way that is supposed to be good I had terrible luck with Ammco recently so avoid them IMO
Performabuilt is supposed to be pretty good built transmissions
FTI does have a good reputation, but mine was installed about ten years ago and there was a little drama with the shop who did it. FTI will rebuild/re-stall my converter but it's going to take up to 3 weeks.
Mine is 2wd, I appreciate the offer Trey, you're a good man.
I met Jamie years ago when I first moved here. I haven't had the pleasure of working with him just talked to him a few times. He's a good guy.
I asked a local trans guy if he would install an aftermarket transmission, and he said no. I had an FLT in my 2dr Tahoe. Yes, Performabuilt are quality, I was also looking at Gearstar.
992dr
992dr
Eastern N.C.
- worn 2-4 band
Is there a specific model Autel I should look for?
I replaced the solenoid with an ACDelco solenoid.
Is the TCC regulator valve the same as a Fitzall valve?
I'm looking for a new trans now, I'll be calling them tomorrow.
I think I'd really enjoy rebuilding it. Unfortunately, it's my daily and I don't have a back up vehicle.
Thanks Nick, I appreciate the help and info.
NickTransmissions
Sin City
Search 'Autel Scanner' on Amazon and review the different options that come up in the search
The TCC regulator valve is the valve...Fitzall is a company that makes updated/corrective valving that replaces the factory valving in that location in the valve body...The problem with the factory valve train is that it prematurely wears, causing later, harsh 1-2 upshifts, TCC problems and other symptoms due to the wear. the Fitzall valve corrects this by sealing off the bore with o-rings...Transgo also makes a .0005-.0007 oversized TCC valve and spring that comes in their SK4L60E shift kits. Sonnax makes an oversized valve kit as well but you'll have to ream the bore using specialized tooling/fixtures.
You're welcome - good luck with it and let me know if you have any more questions.
992dr
992dr
Eastern N.C.
Ok cool, I'll search tonight for the scan tool
Gotcha, Yup, I installed a fitzall valve for that reason. I had work done a long time ago (have a thread here somewhere), it's a long ridiculous story.
Thanks again
992dr
992dr
Eastern N.C.
Well, it's been quite a while, and it hasn't worked itself out but it's staying together :rotflmao:
I think I might be going a different route than the 60E. Only because my diesel mechanic friends partner at his shop is a GM tech (who's building a bad ass 1st Gen S10) with some tuning capabilities and I found a rebuilt 04/08 80E w/converter and 1 year warranty and no core for less than even the basic built 60E.
This is just in the talking faze as of now I'm waiting for him to squeeze me in to get it on the computer and get a thorough diagnosis. I'm just hoping to get in with him this week, not the greatest time of year for things to happen especially "favors" I certainly don't want to burden him. Plus, I'll get a nice roll cage tig job out of it :)
More to come enjoy your weekend
992dr
992dr
Eastern N.C.
Man, this has been a long road, of course it has to happen this time of year.
Still nothing but finally connected with the tech and will be going to see him next Tuesday, we'll go for a ride, and he'll log everything to see what's exactly going on and we'll go from there.
I hope everyone has a Happy Holidays and gets to enjoy some family time
992dr
992dr
Eastern N.C.
Met up with the Tech this morning hooked it up and went for a ride.
Long story short no swap at this time, so, I'll be replacing my converter.
992dr
992dr
Eastern N.C.
@NickTransmissions going through some older threads I saw you mention the thickness of the converter clutch being at least .050 thick and your builders are .070 thick.
The brand I'm looking at use woven carbon clutch packs and are a standard .020 thick. Lighter better materials but at what trade off. It's not a reman and it will also have a billet front plate.
What are your thoughts?
Does your builder have them with billet front plates?
NickTransmissions
Sin City
It's your money, do with it what you want but I have never heard of anyone making the trade off you mention above when it comes to converter clutches...Are you saying the "lighter" clutch somehow provides measurable gains over a thicker (and vastly superior) clutch? Or am I misunderstanding?
Billet covers arent needed unless high performance or frequent HD towing/hauling.
Bambiii
