Compressor Mounting Location on a PPV
blewisemt
USA
Hi all. I've got a 2020 PPV with both batts still installed. I'm looking for somewhere to mount an ARB twin compressor, and most recommend the normally-empty aux batt tray. Any recommendations?
blewisemt
blewisemt
USA
I do. I've got enough lights and other equipment that dual batteries are a good way to go.
it might fit where a autoride compressor normally goes behind the drivers rear wheel, you would just need to source the mounting cage or make one
does the twin adjust like the single does, I have the single in my silverado if you loosen a nut it can be turned sideways basically.
KodiMoe
