mattbta
Frisco, TX
Note that the OE tees have slightly different angles for the rear heat hoses. I don't know if Dorman has the same.
Looks like they have two models as OE does. Intrigued, however I just bought GM tees a month ago to put in. Might still have to try these.
EDIT: For $45 on RockAuto - why not? I'll keep the OE in case they don't work out.
BigDogYJ
Earth
Replaced the parking brake release handle/cable on the wife’s 04 Yukon. Couldn’t locate a Gm original. Settled for some knockoff on Amazon. Seems decent. We’ll see how long it lasts.
At least it’s a simple job and when it fails you can still release it by hand fairly easily. These are the only things I don’t mind trying a cheaper alternative with.
mattbta
Frisco, TX
I did the same with the hood release - no name on amazon was quicker.
dps01
N. TEXAS
Enjoyed a nice day in North TX.
Changed 22 year old bulbs to LED…DRL, turn signal, backup, and brake lights. Installed a LED compatible flasher… without loosing a bunch of skin on the hands :D.. pleased with results; no hyper-flash… life is good.
In the process, broke and repaired mounting tab on tail light assembly.
strutaeng
Dallas, Texas
My 99 Silverado has been leaking at the tailshaft extension housing since I swapped that transmission. I hate oil leaks. So today I went and bought a seal replacement. USPS was supposed to deliver my crankshaft seal for our 3.6 Pentastar minivan that's getting a wobbling harmonic balancer replacement...but of course, they are late. So I decided to paint my driveshaft to waste time... SMH
jephilip
