Looking to buy a work truck. Need expert assistance.
S33k3r
Dallas, Texas
Thanks for informing. By the way I will need to swap out towing mirrors. They are automatic, but only with adjustment. I want to make them fold automatically. Do you happen to know how to do it? I saw some on Amazon for $100 with automatic folding, but how to make it work with my Yukon XL, I have no idea.
Currently, there are no power FOLDING or EXTENDING mirrors for our generation of truck. I have a friend who is supposed to be engineering him, but there is one project ahead of this he's working on.
Ok, that was an accidental lie. There is one company I just remembered (but not their name), and I'll dig them up if you want me too. I forgot about them, sorry.
S33k3r
Dallas, Texas
I have the Rancho 9000 adjustable and I like them. Not expensive either. Highly recommend and can be bought on RockAuto.
Don’t do 20s. Will sacrifice ride comfort. Stick with 18s.
The window is likely the regulator. I think those are known to go out. I think there are several threads talking about it.
I can't say about the Yukon XL / Suburban 2500 ride, but 20s on the 2500 HD did not mess up the ride for me.
S33k3r
Dallas, Texas
Got and abs light. But it glows steadily not flashing. I hooked up a scant tool. Appears to be front wheel speed sensor. I ordered it from Rockauto already. Should be by the end of the week. Also I would need an oil change. Sometimes light is on sometimes it is not. I think I will do both of them at mechanic shop. It's not a complicated job. I will have to use to this truck. It's huge, but still not as huge as my Sprinter. I will add top view rear camera and parking sensors to it. And also will remove rear bumper. I will install Street Pan roll. And modify the towing hitch. Those few inches play a lot in NYC.
Don't forget your roof rack! That will hold some of your stuff.
The towing hitch relies on the two bolts run through the bumper for stability/strength. If you go to a roll pan, you will want to switch out hitches entirely.
Also, check your grounds. That could be causing the ABS light to randomly turn on/off as well.
Congratulations on your purchase!
S33k3r
Dallas, Texas
Have someone tried These wheel adapters. I can't find budget wheels for 8x165.1 maybe I could get lucky with 8x180. Looks like my truck has factory 2 inch lift. So I should be good with 20 inch rims. I'm not planning to install huge 33" or 35" just a bit more stylish rims. Tell me what you think
I advise AGAINST going for adapters. There are plenty of rims out there for the 2010- GM, 8 lug trucks. You could even get some oem takeoffs -- from RAM!!! -- from 2024/2025. RAM and 2010- GM 8 lug trucks run the same 8x 165.1. How do I know? Check the vehicles in my sig. :Big Laugh:
I got the wheels for my truck off of FN Marketplace. They are Xtreme Mudder wheels.
I think I paid $300 for them; they are 20s. I did have to replace the caps, which -- for Xtreme Mudder -- were $49.99 EACH. I found Moto Metal wheel caps for $19.99 each, and they fit like a champ. I did have to get new bolts to hold the caps down, though.
Now I have wheel locks on the rims, plus secure torx holding the caps on. None of that will stop a dedicated thief, but it will take him forever to get them all off.
M
makintoshnex
Who may assist with issue. I have steady glowing park brake light. When parking brake is applied it flashes then ( I think it is normal when it flashes) . Brake fluid level seems to be ok. Can it be brake fluid sensor, or some ground?
Super Moderator
Elev 5,280
Please start your own thread in the appropriate year section, and tell us more about your vehicle: year, make, model, engine, etc.
KodiMoe
