Show off your 2015+ leveled Tahoes and Yukons!
Jeff_
Scottsdale, AZ & N. Idaho
Tahoe_Rx
Damnit. This looks too good.
Thanks for sharing. Good inspiration for me to do some day.
Here is one more until I have time to take some decent photos and do a full write up haha.
Rustylane7
@Rustylane7 - those could be a bit too tall with stock suspension. I was running 33" tires with a 2-3" ride height increase up front and clearing fine with that.
I'm just going to go for it. The z71 seems to sit higher than a regular hoe. I'll report back with pics.
Rustylane7
How do they ride? I had Fox 2.0s on my 2011 F150 and they definitely stiffened the truck up but was satisfied overall. Im leaning toward the Billstein 6112s on the tahoe just to try something different. Or possibly the Dobinson kit.
Tahoe_Rx
Ride is great. Stiffened up some; eliminated nose dive when stopping, nose dive or lean when cornering etc. but still comfortable. Biggest improvement is the rebound after a big bump. On the stock suspension I would bounce up and down 3 or 4 times after a big bump before the suspension settled. Now you go over the bump and it immediately settles. So instead of feeling like 5 bumps it feels like 1 bump
Tahoe_Rx
I considered the 6112s but it seemed like you could only get 1” of lift out of them and they don’t recommend running a spacer on top. That is ultimately what pushed me to the 3” Cognito lift.. only other choice would have been a Cognito 3” lift with kings instead of the Fox 2.0s. The kings 2.5 probably feels more similar to the 6112s. But the kings were not in the budget at the moment
Oh Kee Pah
MAINE
Job well done - great overland build going!
A couple suggestions that probably wouldn't hurt your budget too much AND benefit the rig/ride:
1) Are the rear shocks built for a 0-2" ride height increase? If so -> New Rear Coil Springs, providing approx 2" increased ride height. (example: Dobinsons https://dobinsons.com/gmc/gmc-53)
2) New HD tie rod sleeves (instantly feel better steering control, particularly low speeds, with larger wheels)
3) New Front Sway Bar Links (extended length to match up better to the ride height increase)
Tahoe_Rx
Do you have links to tie rod sleeves and sway bar links that would work for this build? I always have a hard time finding parts that work on lifted 15-20 tahoes
Rustylane7
Does anyone in here have pictures and feedback on the Dobinson kit?
Tahoe_Rx
This has been a great 3 year journey - Thank You TYForum and Members for all your thoughts/posts/opinions/photos to help get me here!
Getting behind the wheel is a blast every single day!!!
View attachment 353558View attachment 353550 View attachment 353554 View attachment 353555 View attachment 353556
Safe Travels!
This has me wanting to step up to 295/70r18s now that I have a new 3” lift on. Currently running 275/70r18s. They fit well when I had a leveling kit but feel small now with the new lift.
Jongrreat
