Steering wheel options
kbuskill
kbuskill
NE. FL.
sure looks similar
Yep, my guess is the Enclave and Traverse probably use the same wheel, and it is probably the same as ours but don't have a way to verify.
Those AZA wheels are pretty neat but way to rich for my blood. I already stumbled upon them but didn't mention them due to the crazy pricing.
The other sites I saw too but haven't contacted them yet.
The Autowoods I was originally looking at was fairly reasonably priced, somewhere around $400-$500 set up just the way I wanted it if I recall.
I just contacted the above vendors and will see what they say.
Does anyone know if the 15+ steering wheels fit/work?
one member changed his to a k2 wheel, I think he had some minor issue's routing the button controls but it mostly worked, have not seen any post's on it in a while. if you search the forum you might find some reference to it. not sure if he ever got it 100% or not.
Xafnyx
I was also looking at traverse wheels, I wonder if those work.
kbuskill
kbuskill
NE. FL.
I ended up buying one for a Buick Enclave. Haven't been home to try it out yet but from the pics my son sent it looks like it will bolt right on.
kbuskill
kbuskill
NE. FL.
Keep us posted on if it works out!
So as it turns out, the Enclave steering wheel runs a bigger spline than a Suburban.
Why on earth GM changed something so trivial is beyond me. That is one thing I have always loved about GM is the way they keep things simple and use the same parts between varying models. Why they decided that it would be cost effective to change things up on the steering wheel splines of all things I do not know.
KodiMoe
