2016 Yukon Keyless Start System.
laracohran
Hey everyone! I have a 2016 Yukon and my passive lock/unlock buttons on the door handles are not working. I saw a thread with a similar problem but wanted to ask if anyone could tell me where the antenna for the keyless ebtry system is located? I wanted to replace it, but not sure where it's located. Thank you!
Geotrash
Dave
Richmond, VA
Assuming you have passive entry (ATH), there are multiple antennas for different parts of the vehicle.
The keyless entry door antennas are located in the left front and right front exterior door handle bracket. The antennas are serviced as part of the door handle assembly. The antennas are controlled by the keyless entry control module. When the exterior door handle button is pressed, the respective antenna will send out a challenge to the keyless entry transmitter, which begins the passive entry communications.
L
laracohran
Thank you for your response. So does this mean I will need to purchase the door handle assembly?
Loki223
Elk, WA
Reading that, i think it means you need a more advanced scan tool to properly diagnose the problem, rather then just throw parts at it. Assuming both door handles have the same problem, and they both started doing it at the same time, i would lean more towards the keys, or the keyless entry control module. The odds of both antennas going out at the same time would be low IMHO. but to properly diagnose it, you'd want to be able to see the signals going back and forth in the computer network to verify what is working, and what is not
Geotrash
Dave
Richmond, VA
Took the words out of my mouth and saved me some time in responding. Thank you.
Yes, more diagnostics are needed and a proper scan tool that can read all of the modules and monitor the signals on the canbus to figure out where the fault is. But if I were going to fire the parts cannon, the first thing I would do is replace the battery in the key fob. A weak battery may be enough to unlock the doors with the fob, but not to get the fob to respond to an inbound request when you press the button in the door handle.
L
laracohran
Welp, I bought a new key fob and got it programmed to my vehicle but unfortunately, that didn’t solve my problem. I’ve checked all 4 doors to make sure the buttons weren’t stuck. I called the dealer and they said it would be 175.00 to run a diagnostic test. Was hoping I didn’t have to go that route but we’ll see. Thanks again for the feedback.
Geotrash
Dave
Richmond, VA
Well worth the troubleshooting fee. And when they tell you their verdict, you can come back here and help you get the parts and guidance you need to do it yourself if you wish.
clogan2
These vehicles can get weird: my '16 Tahoe, LTZ, had the coolant temperature sensor go bad. Or maybe it was the thermostat. In any event, when it happened, my radiator fan defaulted to ultra high speed whenever the engine was running. While this was going on, the door lock/unlock buttons on the exterior door handle would not work. Once I replaced the coolant sensor and the T'stat, the locks work as intended.
Go figure.
DSLmag
