EddieC
- Joined
- Aug 9, 2014
- Posts
- 724
- Reaction score
- 572
My experience is different. I had abnormally low pressure after an oil and filter change, swapped the filter and it came back a little above the historical normal. The Standard Napa/Wix did the trick.None will HELP with oil pressure.. That's a mechanical situation ...
I use the wix oil filters on my 14 6.2L
57060 or 57045 using the XP line is up to you.
Make sure you are using correct 5w30 Full Synth Oil
