So lets watch this entire mess unfolds.
Are ONLY the 2021-2024 that are UNSOLD recalled?
What about all the 2021-2024 on the road? Maybe GM brokered a deal where they only will provide an oil fill cap, an adhesive note for the Owners Manual for the 2021-2024 models on the road, not even a free oil change to 0W40.
2025 Owners, GOOD LUCK!
Not all the rest of the owners use the same oil or drive or operate the vehicles under the same conditions.
The SINGLE BIGGEST threat to these engines is how the TCM is programmed to pull max torque at very low RPM's on the highway. How many of these engines failed at 70 MPH on the highway? Most of them.
The next BIGGEST THREAT is fuel dilution of the engine oil. Too many short drives in cold temps, too much use of the Remote Start to warm the engines up, too much engine idling for warm up from cold start. Too long between oil changes, sure follow the OLM, but you are a FOOL. Change the oil when the OLM hits 50%.
EVERY light duty and heavy truck on the road is in jeopardy of engine failures if they continue to use 0W20. Disable the Auto Stop/Start, disable the DFM. Then you are hopefully have something reliable. Otherwise you are gambling.
The NEXT GM fiasco unfolding is the valve body problems with 10 speed transmissions.
Just search my user name, you will find more than you care to read about the engine and valve body problems!
