Monstar_est87
City of Angeles
It processes faster then the black box and is capable of more tuning things... Like wat im not sure..? I havent gotten in2 the specifics of that but its a better pcm for ur truck... Think of it like ur truck came stock with an iphone and u upgrade to anything else basically...
Tricky
Illinois
good luck with that. You can't hide anything in the yards around here. :lol:
I know, but I didn't think the first 120 speedometer would be there weeks later let alone another also, that's why I didn't think to bring $$, cause I was just browsing, getting fuses and and bulbs.
Sent from a Phone Booth using Tapatalk
slipping
Rosamond, CA
http://www.gmtruckcentral.com/articles/12200411.html
and to give you an ideal on its capabilities, if you were to change some hardware components and pcm with the right tune on that can do COP for a vortec 350.
Thats a good read. I'll sit down at work and go through it.
Got some goods in
McFizzl
Broke as a Joke.
Fayetteville, AR
Came out to a truck that wouldn't start. Found out the old distributor cap was causing the cylinders to misfire on opposite side. Luckily I didn't damage the crank. New dist. cap and rotor installed and she's running like a champ!!!
qukon 95
i have a antifreeze leak and found that i need a water pump went
and got one i painted it red. i got it at autozone the old one has been on there sinse 06 and it's a L T R one weather is cold right now.
Shadfrmdabull
