AtomicHoe094
Atomichoe094
cleveland, OH
Installed the modded tbi unit today (ultimate tbi mods, 1/4 pod spacer, flow matched and cleaned GM injectors, rebuilt the tbi unit) runs a lot better got rid of the annoying shake at idle too
Sent from my HTC One X using Tapatalk 2
Looks good man, nice work.. Is that a MSD coil? Mine failed within 1 year of buying it. Have the stock one back one.. :disgust:
95escahoe
Thanks, and ya it is, I have had it on for close to 2 years now and no issues, read that it was an issue shortly after I got it and that the Accel one was better
qukon 95
For me to open the left barn door I would have to push and pull the door while at the same time
Pull the handle I guess that rod gets weak it's not ridged so you will have to take the panel off
Disconnect the bottom rod from the latch, unbolt the locking latch under the door, then pull rod
Out add small washers (I added 4) put back together now I can pull the handle and door opens
With little effort. 2 yrs ago I used a rubber hose on it and it worked then it came off with the washers
It should last for a London time.
95escahoe
That barn door issue could be the bottom latch is shot if you have to push the bottom in mine did the same replaced it, its as good as new
qukon 95
how much did that cost? london !!! lol thats from using my cell
phone and my fix cost me $1.05 i did a pic of it www.photobucket.com/qlcp
---------- Post added at 07:40 PM ---------- Previous post was at 07:20 PM ----------
so... what was the purpose of this mod so i will know ::drool:when i
do this.
noJeepshere
Bountyfull, Utahrd
Replaced the idler and tensioner pulleys in an attempt to silence the mice under the hood. Didn't work. I think it might be the power steering pulley.
briwesric
