Lq4 6.0 for my Hoe
bottomline2000
bottomline2000
Dallas, TX
added hydroboost
Dynatech headers fit like a glove..
bottomline2000
bottomline2000
Dallas, TX
Painted the stock intake because I knew most of the block would be covered up..why not.
And battery tray since I still had paint and was bored..it's duplicolor engine enamel chevy red/orange and their ceramic clear.. holding up like new on the block..
bottomline2000
bottomline2000
Dallas, TX
and here she is running!! big thanks to Justin at Blackbear Performance for getting me up and running. going to send a data log to him to fine tune it, but she runs good.
bottomline2000
bottomline2000
Dallas, TX
nice job , mine is coming real soon , can't wait. any issues durining install ?
Thanks man and yeah there were a couple of issues and all trans related. First was the flexplate install and almost cross threading one of the bolt holes. My engine came with a 4l80 flexplate and I switched to a 4160 plate. I tried to use one of the 80 bolts to break up some of some of the thread locker/oil deep in the crank and it caused a bur in the threads since the bolts use a spacer and don't thread all the way to the top of the bolt.. the ARP bolts I used fit tight in that one hole and I almost stripped it but it worked out and torqued down fine after a nice scare..
The next was the torque converter. If you swap it out make sure to measure the depth of the snout before you pull the stock one. I thought the cicle d had seated after it slid down twice, but after comparing the depth of the snout it wasn't deep enough so I had to pull it back out and then got the right plunge depth on the 2nd try. I read about guys breaking their trans pump by messing up this step.
Everything else was straight forward. I would recommend pulling and installing engine with the intake off. It frees up a lot of space and makes putting everything back together a lot easier.
bottomline2000
bottomline2000
Dallas, TX
Also, I went ahead and pinned the crank for future plans. Don't cheap out on whatever kit u use if u do this. I used an ARP crank bolt since it can be reused if I ever have to pull it, plus it looks cool lol..
bottomline2000
bottomline2000
Dallas, TX
Last use the right tools. Guessing and estimating wasn't going to work for me so I torqued everything to spec.
Ls1 tech valve spring tool
Crank balancer install tool. Don't use ur crank bolt to do this!! Ebay kit also came with crank locking tool..
Sac City Corvette alignment kit
Hopefully this all helps the next guy. I had to do a lot of research to find all of this and put it together and I say it got the job done.
#1taho
5150TAHO
niagara falls ont
That's great. I will be taking some of your advice and apply it when I do my install. I was going to put the intake on before. But will be waiting now. My tranny came with the motor so I am good in that department. How do you like the new found power ?
bottomline2000
bottomline2000
Dallas, TX
It just has more grunt. Even with 3.42 gears it gets out the hole nice. I just push the gas and it just goes so much easier. It feels like a bigger motor and with the cam it just pulls. I can feel the torque management kick in after some shifts but it smooth. It cruises 80 with ease...no downshifts..should be better after I send a data log back to blackbear.
Just a fyi, I had a problem with my fuel pressure regulator dumping fuel in the intake. Bought a new delphi unit and it buzzed..switched to a BWD branded one and problem stopped. I would have already got the update from BBP if it hadn't been for this screwing up my last log.
Travieso
Boooooooost !
Los Skandeles, CA
that's awesome, What type of paint did you used for the block and how did you prep it? did you used clear coat and primer?
Second Do you have a part number for the Flexplate and flexplate bolts are you also on a 4L80?
Stevemo70
