LanceD's PPV Thread
CrashTestDummy
Pearland, Texas
The larger diameter pipe can only help. Was it a bolt-in swap, or did you have to modify anything? Looks like the front connection with the y-pipe may not be the same.
LanceD
LanceD
AZ
It was different. I ended up using everything aft of the manifolds and everything fit perfect. All of the hangar spots are the same.
kbuskill
NE. FL.
Aside from the sound... did you notice any difference in performance???
Good or bad... I was curious how the smaller engine reacted to the bigger pipe. Can you tell if it lost any torque?
LanceD
LanceD
AZ
It's hard to say. Maybe a few HP if I had to guess. But it sounds faster haha
LanceD
LanceD
AZ
Ordered a 9.5" 14 bolt hybrid axle today.
LanceD
LanceD
AZ
Checked operation of the locker and ran a few cans of brake cleaner through it. Sanded off most of the bubbled paint and rust. Fresh coat of rustoleum satin paint and some Lucas 75w90 and I think it's ready to go in. Just have to measure my u joint to see if it needs a different one.
dangerman4203
