07 Tahoe engine hot ac turned off
iLikeEggs
Potato!
Oregon, USA
This morning I got the "Engine hot/turned off AC" message and the fans were screaming. There was no overheating and no CEL. This happened to me a while back. Turned out it was a bad connector on the pig tail to the engine coolant temp sensor. I replaced it along with the sensor and it fixed it, until now. Both parts were Duralast. I happened to have a spare pig tail and an AC Delco CTS so I replaced them. I also cleaned the negative terminals on both batteries and pulled the ECM fuse for about a minute. Started up and problem solved. Winning....for now anyway.
Tozan
Overlander
Yavapai Arizona
I found a really easy fix on my Cold Case... Just take an empty / fired 45ACP case punch out the primer then shove it in the upper hose going to the overflow tank and reconnect the hose...
UPDATE: I removed the coldcase radiator last year because it split at the seems... I no loner recommend Cold Case...
kbuskill
NE. FL.
I would’ve had to send it back so they can inspect it and determine if it’s warranty or not. Then wait with no radiator while they decide and send another POS. I was annoyed so I went back to OEM (Denso) and recycled the thing.
When mine started leaking I called them and he had me send pics and they sent me a replacement and I kept the old one. Just FYI.
New design fit much better and I haven't had any further issues, but only time will tell.
Geotrash
Dave
Richmond, VA
I probably should have called, but their return policy, as written, made me think it wasn't worth it. And, after all of the problems with them others here have had too, I wouldn't have trusted the thing anyway.
dapdapdap
