bowtiegurl
I have a no crank no start situation in my 07 Yukon 5.3 l. A bi-directional scanner is unable to communicate with it. There is no power going to fuse #56 ECM-IGN. Don't have a clue where to begin figuring out the cause.
Whoa... that's a lot of back story...I think you should keep everything in your first thread -> https://www.tahoeyukonforum.com/threads/replaced-engine-now-no-crank-no-start.149652/
That way people can see the whole backlog.
Similar story here -> https://www.justanswer.com/chevy/ffdlp-b1019-3a-code-2008-suburban-no-crank-no-start.html
Their issue was the RUN/CRANK relay going bad. (which powers your ECM-IGN fuse among other modules you have codes for)
I apologize for so many post. How do I keep everything in my original post?I think you should keep everything in your first thread -> https://www.tahoeyukonforum.com/threads/replaced-engine-now-no-crank-no-start.149652/
