Service Stability System Warning
m1949
m1949
LS364/450
MS Gulf
I think I found and corrected the problem. It was a bad chassis ground contact for ABS module located beneath driver side door. GM actually published a tech bulletin about this problem. I removed the ground, cleaned everything, tightened it back up using new nuts, washers and bolts mentioned in the bulletin then coated it with flex seal as per the bulletin. Haven't had the message come up since doing that!
adventurenali92
Big Bear Lake, ca
Sweet! Cheap easy fixes like this are the best!
Marty_S
Not sure what your goal was with this comment but ok.
Nothing like a good cornice jump. If it breaks drop into tuck and go, go, GO. Was not meant in any bad way. Been skiing for 65 years now and hit 70 last month. Hoping to get some days on my 223cm Super G boards this coming season.
Alphaniles
