Kman
Southern California
Found a 63 inch cargo cover on Facebook Marketplace for $80. In perfect condition and works perfectly. It’s a shade darker gray than my interior but I’m so happy. These shorter Tahoe cargo covers are hard to find and usually a lot more money. The longer 66 inch model for Suburban and Yukon XL are easier to find.
Does anyone know or remember if LT Tahoes back in 2001 came with the cargo cover as standard if you got third row seats? I am the second owner of my 2001 LT Tahoe and I know the first owner well. She swears she never got the cargo cover when she purchased the Tahoe. I know that the cargo cover doesn’t work with the third row in.
I'm almost positive the cover wasn't standard in any gmt800 Tahoe. If you wanted it, you had to order it. I could be wrong, but I don't think I am. Nice find on the cover. Very hard to find. I actually have a spare, but it's light tan, and I have the pewter interior.
Tri5Garage
I tore down the hub and axle assembly’s on my Escalade. The PO thought the differential was going out. Hopefully my new hub and replacement cv boot gets here soon.
Kman
Southern California
My Sonar LED tail lights started going out after 12 years. Bought Dorman factory stock 2004-2006 tail light housings and installed them on my Tahoe. Used LED 3157 bulbs for the turn, reverse, and brake lights. Really happy with how they turned out.
Keviebear86
Today was rather expensive for me, and I work at a repair shop so I get parts at cost.
Front sway bar links (fell apart when removing front CV shafts)
Extended travel front CV shafts (hoping this fixes my binding issue in 4WD, I'm lifted 3")
Rear sway bar bushings and links (both were worn and rattling)
Turn signal/cruise/wiper switch (cruise deactivates when I use the turn signal)
4WD switch (damn buttons fell out of it and I lost them)
At the end of the month I'm getting my new tires installed and I'll have to trim my inner fender liners in the front so they don't rub. And shortly after that I'll be replacing the factory gear box and realigning it. The gear box makes a groaning noise and feels rough when turning left only and I have replaced every single other piece of the power steering system.
latvius
Ariton Alabama
Am I the only one who didn't know they made these? Always thought I would have to go to the junkyard or aftermarket ones which cost too much money (for me)
Has anyone bought these?
ScottyBoy
Shreveport, La
Went and checked for updates on her refresh….
If you don't mind me asking, what city are you in, and about how much is your painter charging you. Because here in Northwest Louisiana, most shops don't even wanna touch a full paint job, and the ones that ARE willing to to it, want between 7k and 11k to prep and paint it. I can only afford about 2500-3000 right now, and even if i could afford more, I couldn't see myself paying 7k for a paint job. But I'm not looking for show car quality either, but i would like at least "new car" quality.
ScottyBoy
Shreveport, La
I've seen them everywhere. Especially on Amazon and Ebay. You can get them with heated mirrors, turn signals, and even puddle lights and markers lights all built in. You might have to run wires for the marker lights or puddle lights though. Every 2003-2006 is "pre-wired" for the turn signals though, so that part should be plug and play.
S33k3r
Dallas, Texas
"Paint Correction" is a thing, and typically runs about $3k-$4k. You could also do a wrap. Finally, you could get a cheap job (Maaco) that needs to be redone every few years for a few 100 dollars.
haloOne
