kbuskill
We finally have an answer after all this time.Gm# 12633653
DEADENER, oil pan
$39.24+TX
I wonder if you took it off if it would make any discernable difference?... somehow I doubt it... lol
DEADENER, oil pan
$39.24+TX
AseI am curious what this plate is on the oil pan of my 5.3L 2008 Suburban LTZ 2WD.
At first I thought it was some kind of inspection plate but from looking at pics of the inside of the oil pan it doesn't appear to have a hole behind it.
So is it some kind of "skid plate" or is it some kind of reinforcement for the cast aluminum pan? Or???
Just kinda curious if anyone knows.
Yup. It was what I read on some of the other replies. Just a plate... a scrape plate. Nothing on the other side but the oil pan.I'm about to find out. I'm changing the oil pump right now. I'm curious to see if it's a quick access to the oil pickup line that bolts to the oil pump. If its not a quick access i guess ill just continue to pull the pan since i already drained the oil. I'll send pics and updates on my findings.
