Idea On Cost To Replace 5.3 Engine? 2015 Yukon XL
BringTheNoise
I bought a 2015 GMC Yukon XL with 207k miles and drove it four times for less than 100 miles and the check engine light started flashing last Tuesday night. It was poring down rain and I was headed up about an incline on i75. The check engine light started flashing and I didn’t notice anything different in the way the car was driving. I pulled over into a gas station and plugged in my ODB reader. No Check engine light remained on but the reader showed a P0307 fault for a misfire in cylinder 7. Drove it another mile home and it was pouring rain. I was headed down an incline and had it in the RWD/4 wd flex mode where it’ll switch in and out of. It was lurching and shaking when I slowed down. I put it in park and the engine was sputtering. I shut it off and called this mechanic that I had booked to replace the struts and shocks. I told him what was going on and he said to just drive it to the shop about four or five miles away. The car drove rough but wasn’t terrible and seemed better at 40 plus mph of less noticeable.
The mechanic couldn’t get to it until Friday and pulled the spatk plug and it was soaked in fuel. I’m my head I figured maybe the injector stuck but I’m not a mechanic in the slightest degree. I brought new spark plugs and wires and same constant misfire. He did a compression test and it was at 0 psi in #7. He said I need a motor as with 207k he said it’s not worth trying to tear apart And fix.
I’m really upset at myself for not getting it checked out more thorough. I work at a dealership and took it on trade in. I always liked these and my I wanted something that looked a little fresher then my 2006 Infiniti. The used car manager said I could have one of the mechanics check it out before I bought it as he was going to charge me $381 for an inspection through the dealership. I went to a mechanic that had that same generation Yukon and figured he’d be the best to check it out. I paid him $50 to do a quick inspection. He said I needed to replace shocks and struts but it seemed solid otherwise. I signed an As Is form and know I’m SOL but the used car manager is a “friend” and I’ve worked at the dealership 13 years so I thought I’d at least let him know what happened. He shamed me and told me I was on my own. I asked if he could let me trade it towards something else and told me he wouldn’t give me anything unless I replaced the motor. I’ve sold many of cars that blew up soon after the owner bought it even as Id and we always either took back the car or fixed it or let them buy something else. I know I’m not owed anything but I’m just really hurt that I’m just getting the middle finger here.
But I don’t know what to do and kind of just want to fold this terrible hand before I lose more and more money. I don’t think I could ever trust this car even if I put a new motor in it. Im just worried the transmission will go next. How much should I expect to pay to replace the motor?
Someone told me to take it to the gmc dealer and get a legit diagnosis but I really don’t want to just keep losing money when I’ve realized that 207k miles just is more the. Most cars last. I redid all the wheels and made it look really good but I should have checked it out further before going that. I’ve got a good looking 3 ton paper weight I guess
Thank you for reading and I value and appreciate any knowledge and/or advice here.
tritron
I bet you need ignition coils and spark plugs replaced You could diy it did pull codes
Multnomah Falls
You have two choices. Either get rid of it and lick your wounds or have a qualified tech/shop diagnose the actual problem. I would want to know WHY it has "0" compression in cylinder #7. Also, sounds like the problem came about after driving for a few miles. The truck may well have needed struts and shocks and was running fine but did that tech check for codes and history? That is a quick check and easily done in a realm of time for $50.
ANY inspection is only going to tell you what is happening NOW and what the scanner shows NOW.
Yes, you made a mistake by throwing looks $ at it before you had enough miles on it to see what happens.
After finding out correct diagnostics, then make a decision about an engine replacement. If you decide to keep the truck and do an engine, you might want to consider a transmission at same time. Lots of overlap labor there. Maybe @NickTransmissions can chime in with his thoughts on that transmission.
B
BringTheNoise
I was hoping that so I bought new ones and still no action in 7. I love the way this truck looks and keep going back and forth between replacing the engine or buying something else. I’ve just realized I can’t truly afford to own this car. There are so many things that are going bad or are bad. It somehow still has the original transmission. Do I know that thing is on borrowed time. I’ve never tried driving it in weather that needs 4x4 so I have no idea how the transfer case is truly or the differentials for that matter. If I put an engine in it and had half a brain I’d sell it immediately and try and get some of my money back but I know I’ll want to drive it if I do that.
The Previous owner won’t return a phone call or text or email (not a good sign).
buckwild27
Best paint that thing yellow cause you got a lemon. And the previous owner is still running from it.
You're throwing the baby out with the bath water. It shouldn't cost that much to have a competent mechanic diagnose 0 compression in a cylinder. It could be a broken spring or something wrong with the valve.
sLickNick
