2025 Tahoe Premier Build Questions
A320Guy
Plan to order the 2025 Tahoe Premier.
We have a 10 month old infant and was curious if people with littles prefer the Power assisted running boards or the fixed ones?
Also curious about the GM Cat Back Exhaust. Is it worth it? Is it too loud?
My employer qualifies me for the GM supplier discount. On a premier it looks like about $3000-$4000 below msrp. Anyone have experience with that? Things to watch out for?
mplunk
Can't speak for the little ones but the power assisted running boards have more surface area to step on, so my guess is they work better.
I have the GM cat back exhaust on my Escalade. It's definitely noticeable and sounds great, but isn't overly loud (my wife has a tahoe without it and there's definitely a difference).
Supplier discount is around 5-6% off I believe. Process is the same except you usually have to provide a number from your employer proving you qualify for it
Adam Boyles
Had power assist running boards on our last Expedition and didnt like them...but we live on a gravel road out in a rural part of the county. Dirt is not a friend of power running boards. If yours will be a pavement princess then you will probably be fine. I ordered a 25 Tahoe Z71 2 months ago and the dealer still hasn't gotten an allocation yet. My first GM order and the process doesnt seem to work as well as Fords. Hopefully yours gets accepted quicker than mine has.
A
A320Guy
Good to know! We have a large paved driveway and won’t be doing much if any off-road. Just snow in the winter time. Not sure if it’s accurate, but the dealer said if we order now it would be available just after the 1st of the year.
Adam Boyles
If the dealer has allocations available or coming up soon the first of the year sounds reasonable. Other dealers around me have 25 models on the lot but the dealer i ordered from hasnt received their first allocation yet. Oddly enough they have already received 2 25 model yukons that are sitting on the lot. Cant even build and price those yet online and they werent customer orders. Hard to fathom why GM would allocate 2 Yukons but not an already sold Tahoe.
ZKWBQD
Make certain the vehicle comes with Apple CarPlay. Some GM models do not. You might not care, but the person you sell the vehicle to later will.
mp5pdw
Is there an on off switch for the powered running boards? My 2010 Escalade had one and it makes sense that it would have one to turn off when not needed.
corrupt
The 2025 Tahoe/Yukon DOES have Carplay.
navyseal334
If you have snow where you live, ice/salt will eventually impact the motor eventually for power boards. Regular running boards don't look as sexy but it's one less thing to fail down the road.
GMCChevy
Senior Member
My Tahoe is the first one of these SUVs I've had with the power running boards and they weren't working when we got it used. Replacing the motors wasn't too bad but hopefully they stay working a while.
The only real advantages is they hang a bit lower and stick out further then the normal ones so as running boards they are more useful. One other disadvantage is the normal ones also block the fenders and door bottoms from stone chips better (but also build up with snow and ice).
jasonsanders42
