2018 Yukon XL Air Cleaner Housing Cover Bolt
Buddy, the only chill that is in order is your triggered reaction to this topic. Relax, it's an internet forum for exchanging information.
I guess I just have a different perspective I used to have to go to the hardware store pretty much daily to keep a business in business...
trying to get a single overpriced and often unavailable separately part from the dealer is often a useless endeavor.
"most" bolts are either metric or standard and either fine or coarse thread, once you have that memorized it's a breeze to find what you need.
then it just boils down to grade of bolt
markni12301
My go-to air cover replacement bolts are pole barn screws. Look 'em up - comes complete with washer and gasket. A strong solid replacement fastener. And I'm right there with you! I fret every time i loosen these things!
tom3
I did the same thing, and those bolts are an odd ball deal too. I finally took the inner fender off and the little bolt was in the front right near the fog light in a little pocket. If you do this pay close attention to where the screws go in the inner fender. I'll never, ever, drop that bolt again.
tom3
And it's not the bolt, it's the principle of the thing.
F
FunkedOut
I had the liner off the truck when it happened.
I looked in the pockets by the fog lights too.
I’m telling you, it dissolved.
F
FunkedOut
I also have done it, try these on Amazon, direct fit.
yes they are. same threads, same shoulder under the head, and the same head diameter!
now I have some spares so I can freely add to my cache in the engine bay.
appreciate the help, gentlemen.
FWTXAT4
