04 Tahoe Alternator Ground?
mikeyss
Longmont, Colorado.
At first I thought it came through the electronics, but turning the radio off the whine continues. I also had someone stand outside as I drove by and they heard the whine from outside.
when I had my nbs and the original alternator took a dump I went to a 160amp Duralast from auto zone and then later bought a 240amp off ebay neither ever whined, did the big3 upgrade
I always kept my eye on the volt meter, usually stayed pretty rock solid in the middle, if it ever started to fluctuate I knew it was the battery getting weak and sure enough it always was the case in California at least where I live battery's rarely make it past 3 years then they start to get weak. with the nnbs they put in a "battery management system" so the volt meter walks all over the place now, you can disable it but I just figure I will go by the historical data and replace the battery's at 3 yrs like usual.
Scottydoggs
NJ
mine also has a whine, but its only heard if the hood is open and im standing over it. i planned to change it but its charging fine still. belt off i can feel it dont spin as smooth as it could. and belt on running you can feel it has a slight vibration to it.
89Suburban
Bull in the china shop
SE PA
How do you disable it? It drives me nuts personally.
Really? Just as simple as that? LOL! I won't hurt anything right? Just he alternator will act normal instead of goofy?
for the most part it will, I gave up and plugged mine back in I figured I will let it do it's job I have two batteries so I should be good to go. I was used to my voltage being stagnant for the most part and oil pressure, now there both all over the place, at least the temp stays solid
89Suburban
SE PA
Thanks to both of you for the info. I would let it go but I get annoyed with a struggling power window at the drive thru because I am showing 10 volts. And my HVAC display gets dim as hell too. I'll give it a try and see what happens.
HiHoeSilver
Away!
Chicago
Hmmm. I've never seen mine go low like that unless there's a battery or alternator problem. Basically what that sensor does is tell the system when to charge, so I see it go from 12+ (healthy) up to 14.5 (charging) and back.
