04 Tahoe Z71 resto/audio
Brian_smith06
Brian_smith06
Heater core adventure shall begin the weekend of the 17th. I plan to drive on down to my dads shop/stay with my parents that weekend and the following weekend.
I will start out on the 17th by gutting the vehicle all the way down to pulling the carpet. If I get it gutted that night aside from pulling dash I will be happy and should make pulling the dash much easier the following day
The 18th will begin by power washing/shampooing the carpet. While letting it dry I will start on the heater core and pulling the dash. Not looking forward to it but required maintenance is just that, Required. While the dash is out I am going to work on sound deadening the firewall. Not sure if I will use any cld however know that mlv will be fully covering the firewall. I have 120 square feet of deadener so may do a sheet just because?
Fingers crossed that only takes a couple hours aka no more than 6 and then I can start on deadening the floor. I doubt that the carpet will be dry and not thinking I will have all of the supplies to finish this so carpet will be left out until the following weekend when I will be able to pick up a bunch of mlv and ccf.
Hoping to get headliner pulled and deaden the roof/reupholster the headliner but not sure this part will get done? Wife pretty much said as of right now my budget is blown from the deadener purchase. Time will tell...
also going to rerun all of my audio wiring as well as potentially build an amp rack for under second row so should be "eventful"
Brian_smith06
Brian_smith06
Worked on my vehicle a bit this weekend. Power washed carpet and got the back half of the deadening done and got the heater core replaced and most of the dash back in.
The bad news. I now have very bad lifter noise. It started this morning when I first started it up to head to the shop to work on it. Really put a damper on my work today. I would have gotten a lot more done had that not happened. Optimistically I may get to do some internal upgrades now?
Brian_smith06
Brian_smith06
Now that I am on a computer vs my phone with sketchy at best signal in my home town I can update this.
Day started off by stripping out the seats and carpet. Carpet was filthy and needed a good power wash. I didn't take any pictures of the process or right before but there will be a picture at the end
While I waited for help on the heater core I went ahead and power washed the carpet and installed sound deadener in the back half. I didn't go crazy with it. I think I only used 15 square feet? Not like I really had any issues back there anyway. I would have done the front half but motor was giving me issues and wanted to spend more time on what actually keeps the car going vs making it a little more comfy inside. Motor is fine now though thank god. I did not want to pull the motor apart to fix the lifters. YUCK
In order to do the heater core we had to pull the dash out. It was the devil and never wish to do this again! That being said now that it is done, hopefully I will never have to do it again.
freshly cleaned carpet and my jl stealthbox. Carpet looks much better than before and I no longer feel the need to buy new. Still planning on some weathertech floor mats though. I also got a chance to rerun all of my wiring for my system as well and it is MUCH cleaner now. Getting to pull the carpet out helped streamline that a bit. I plan to build an actual amp rack sometime soon that will properly hold all 3 of my amps. Should be much cleaner
Brian_smith06
Brian_smith06
did get some work done last night. This piece was starting do drive me nuts. It's the piece that goes in the headliner that holds the dome lights and ac controls for the rear. Turns out 2 of the 4 clips that holds the ac controls in broke off so that was the culprit. As you can see I put some cld around it to hold it in place. I also stuffed some foam in there as well. It worked like a charm! I didn't need the deadener in there other than to hold the ac controls in place but figured why not. I have 120 square feet of it.
also started with properly aiming my tweeters. This made a world of difference. I knew it would help but wow I did not expect it to change this much. My harsh s sound is finally gone. I assume due to no longer being aimed at my windshield? You can see where I had them installed and where they are currently. Final goal is to fiberglass them as low on the a pillar as I can on axis. After doing this I no longer feel the need to upgrade and I was hardcore looking at some scan tweeters yesterday
also what really spawned me working on my vehicle last night is there there is some rattling witch craft going on inside the dash from when my brother helped with my heater core a few weeks ago so I am going back and redoing what he did. Also have a bit of alt whine at times so wanted to redo the ground on the deck. Do you think 8 gauge directly to the battery would be overkill? Have also looked into doing a small capacitor in the power line as well.
I wont be putting the top part of my dash on until I have the ground/rattles resolved. Wife isn't happy about that but to make her a hair happier I put a layer of ccf on top of dash to cover all of the internals. I think that actually irritated her more than pleasing her
Brian_smith06
Brian_smith06
Not anything big going on but progress nonetheless. Pulled the front door panels off to do a little deadening. I still need to actually deaden the doors themselves. I'm holding off on that until I have ccf and mlv to properly finish up my doors. Only ended up using 1.5 square feet. Had originally planned on doing 9 square feet per door panel. Here I am thinking 120 square feet isn't going to be enough and I'm using a fraction of what I anticipated.
also worked on the switches in the doors. They just didn't fit quite right so I did a little deadener in there. I know ccf would have been ideal vs cld but only had cld
tgui
I can't wait to see how this all turns out.
Cash_88
Wichita, KS
I always thought you needed the whole panels covered and wondered why increments of so little were often sold for the deadener. I also ventured down the path of heater core replacement when I replaced my a/c evaporator...I too wish to never do it again
Brian_smith06
Brian_smith06
imo its definitely a piss poor design on gms part for doing the heater core the way they did. That being said im not a designer.
With deadener the real rule of thumb is 25% coverage. Now mass loaded vinyl on the other hand you do want 100% coverage. Its what actually blocks the noise. Some companies market their product by showing panels 100% covered by their cld but its not truly necessary. Im not saying it'll hurt either though. When I pull the headliner I plan to go a bit crazy with the deadener. Im only willing to pull it out once
---------- Post added at 11:37 AM ---------- Previous post was at 11:36 AM ----------
Thanks. Me either. And my wife is really looking forward to me putting the top part to the dash back in. Its driving her nuts. Doesn't bother me though.
Cash_88
Wichita, KS
I'm still on bare interior Tahoe mode while painting panels black. Only thing in it is the center console and both front seats. Which route should I go before I put everything back in? And how much and from where?
Brian_smith06
Brian_smith06
the picture I have above of my floor deadened is only about 15 square feet. It only goes up to where the back of the center console is. Id say you could get away with doing the whole floor with 25ish square feet. You will want to do a mass loaded vinyl though if you really want to block noise.
This is a great option for cheap but you will need to add a closed cell foam to help decouple it from the metal
http://www.homedepot.com/p/Unbranded-4-ft-x-8-ft-Acoustical-Barrier-DB348X96BX/100663624
this would be the best option for mlv. Its what I will be using in my doors. Its far from cheap but a very good option if you're willing to pay for it. I have about 3 sheets left over from my old car
http://store.secondskinaudio.com/luxury-liner-pro/
For sound deadener I highly recommend this. It is the best bang for your buck on the market right now. I would have used it but scored all of my dynamat brand at about 2 bucks a square foot
http://www.ebay.com/itm/KnuKonceptz...H_DefaultDomain_0&hash=item58966077e8&vxp=mtr
or
http://www.ebay.com/itm/KnuKonceptz...H_DefaultDomain_0&hash=item5aea3cf6ec&vxp=mtr
Tinkerer4
