07+ Brake upgrade on a 00-06 NBS, is it worth it?
pnwdan
Cunning linguist
Arlington, WA
well mabye i wasnt that clear
i found a great deal of GMT900 Rotors and break pads so the mod is to replace the Front GMT800 rotors with GMT900
the question is can i also install GMT900 Rear rotors on GMT800 rear
"the deal was a ceramic rotors and pads but the sho[ only supply GMT900"
Like I stated.. swapping the rears would be a downgrade so I think nobody has done it. No way to know for sure
khaled_94
i guess i'll take the risk and try it
but last thing to check the rear GMT900 rotors are 13" right?
lowAZhoe
Resident GM Tech
Phoenix, AZ
The rears do not swap as I stated in my previous post. The gmt800 rear is already better than the gmt900.
If you want better brakes get the 14" upgrade using stock calipers.
hertahoe
Washington
Well I got all the parts to start this project tomorrow - pads, rotors and calipers. Got the slotted/drilled and ceramic pads (only wanted slotted) but I got a good deal off Amazon for $164 and ended up paying $100 for both calipers from Advanced Auto. Hopefully it all goes smooth and my wife will be safely stopping once again!
metelhead
Whats the wheels size you can run with 14"?...(asking cause my snows are still on 17"...would like to see that change to 20" once the tires wear out or get sold)
In my experience regarding brakes- the bigger the better. 14" with good rotors/pads should improve stoppage dramatically...
YukonXL04
The Riverboat
Arlington, TX
So how many of you wanting to upgrade have hydroboost? Mine does. I'm running the factory set up and mine stops great for what it is. Stops way better than my last sierra did I'm assuming because it has more weight on the rear and doesn't just lock up...
Does it stop like my acura tl does? No but it weights almost twice as much... I have yet to have a oh shit moment I wasn't able to stop in time for and I'm a pretty aggressive driver.
Get SS lines. They make all the difference in the world.
Are you talking braided lines to replace the rubber lines at the wheels or the main lines or both? I was thinking about replacing the rubber lines but not sure if it's worth it.
stephygee
Just Steph
Erbil/South Los Angeles, CA
Yes, steel braided brake lines to replace the rubber ones. Don't half *ss it, you'll only piss yourself off. When I went from 24" to 26" wheels, I upgraded my brakes and it didn't make much difference until I added Russell stainless steel brake lines.
Jordan0277
