07+ Brake upgrade on a 00-06 NBS, is it worth it?
Blue 04 Z71
Reading PA
They aren't front calipers. When I buy pads I buy them for a 2003 suburban. They are just the SUV dual piston rear calipers
MadDogDelpho
Texcellent
Texas
Seriously considering this upgrade after my little accident the other day. Anyone know the best place to get all the parts together? IMG_1329.JPG
TheAutumnWind
odd listings for rockauto then.
Can you show specifically what rotors and calipers you purchased?
jarydM
Lost in the Woods
Tennessee
Seriously considering this upgrade after my little accident the other day. Anyone know the best place to get all the parts together?View attachment 78552
My goal is to pick up some Calipers from a junkyard for the front rotors, and just refurbish them myself, and paint them. Them get some of the 13in powerstop rotors for the nnbs trucks, and some SS lines. Not in a hurry on this though, gonna start browsing the junkyards now that the weather is good enough.
MadDogDelpho
Texcellent
Texas
I figured a junkyard would be the best bet. Or people parting out their trucks on craigslist. Are the NNBS pickup front brakes the same as on the SUVs?
Huh, this whole time I had no idea that the SS had dual piston rears. Looks like according to Rockauto they are just front calipers in the rear!
FitsRear Left; Silverado 1500 HD; with Phenolic Piston Caliper
OrFront Right; Silverado 1500 Base Model; Rear Disc brakes; with Phenolic Piston Caliper; with Brake Code JC4; GM Brake Codes are on the "Service Parts Identification" sticker.
OrFront Right; Silverado 1500 Base Model; Rear Disc brakes; with Phenolic Piston Caliper; with Brake Code JH1
OrFront Right; Silverado 1500 Base Model; Rear Disc brakes; with Phenolic Piston Caliper; with Brake Code JH2; GM Brake Codes are on the "Service Parts Identification" sticker. (Only 6 Remaining)
The NBS rears are actually better than the NNBS rears. They're dual piston 13". NBS had 12" fronts and 13" rears dual piston. For the NNBS they switched and went with 13" fronts and 12" rears dual piston. So if you switch to the NNBS fronts on your NBS you now have better brakes than the NNBS, 13" front and rear dual piston.
Blue 04 Z71
Reading PA
You must run 17" or larger wheels for these front calipers. My 16" steel spare does not fit anymore. Just a FYI
Power stop s4918 calipers for the front
Ac delco 18A1705SD or raybestos 580279per for the 13" front rotors.
Pads for the front I got the power stop z361092
Rear I have OEM ceramic pads on
The raybestos
580165per
Hope this helps
Alsherooqi
