07+ Brake upgrade on a 00-06 NBS, is it worth it?
TheAutumnWind
Don't forget about the spare wheel as well. It's 16" on GMT800, so you need to replace it as well
It would still fit on the rear. If you had a flat in the front you could swap back to front and replace the rear with the spare
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Also--isn't this option only good if you have 2wd? I've read running different size tires will ruin a transfer case in the front--and can't be good for your rear either.
If the overall diameter and circumference is different then you would have an issue. We are discussing different wheel and tire combinations that have the same diameter and circumference so there won’t be an issue.
HiHoeSilver
Away!
Chicago
I think AWD is the real bugger here. I agree it can't be great either way, though.
Mine are different since the new shoes. But, I say 10 ply LT rated tires ftw.
Sasquatch
Orange County N.Y.
When i went to 20 inch wheels i got a spare from an escalade in the junkyard that had 20`s from the factory, I can`t remember the exact size but it is very close to the same diameter as a 275/55/20 and fits perfectly in the spare tire location.
ivin74
05 NBS Nali
Htown, Texas
Do you mind posting some pictures of the spare on the spare location.
drackill1
