07+ Brake upgrade on a 00-06 NBS, is it worth it?
wjburken
Eastern Iowa
When i went to 20 inch wheels i got a spare from an escalade in the junkyard that had 20`s from the factory, I can`t remember the exact size but it is very close to the same diameter as a 275/55/20 and fits perfectly in the spare tire location.
My AWD 2013 Denali XL came from the factory with 4 20” wheels and a 17” spare.
Key is circumference of tire, not diameter of rim. That being said, the spare is there to get you to a place to fix or replace the good tire.
AWD is much more sensitive to circumference differences as the t-case and front diff are always engaged. On a 4WD vehicle, they are not engaged while in 2WD.
I have done double tire changes on 2WD cars with the economy donut so my drive axle has same size tires on it.
iddqd
San Francisco, Comifornia, USSA
All GMT900+ have 17" spare. You just need to play with the tire size to match the height of ur other 4 tires. Try to choose the most narrow, otherwise it will stick out too low under the back.
I am running 275/65R18 now, so my spare is 255/75R17.
In the future I am going to run 275/60R20 for summer and 275/70R18 or 285/65R18 for winter, so I will replace a spare tire accordingly.
This site shows u all the measurements:
https://www.1010tires.com/Tools/Tire-Size-Calculator
PS. I think it's a bad idea to change flat tire in 2 steps (if you have 16" spare). It is already dangerous to do it once, why subject yourself to double risk?
Sasquatch
Orange County N.Y.
I tried to get a picture but there was no way i could get the whole wheel and tire in the shot. The tire size was a 265/70/17. It does fit up there with room to spare though, I think i have heard guys here say that a 33 will fit under there.
mountie
Somehow, I didn't notice this thread....... I am planning to get PowerStop rotors/calipers - GMT900 size for the fronts and their '05 pads for the rear. of my '05 Yukon........
I just had my brake fluid flushed...... I WISH I thought of changing my brake lines to SS when I had the fluid flushed..
mountie
Just went through all 40 pages of this thread. Great info!! Page 5 seemed to have all the part numbers you need.
I need to change my rotors / pads. Figured I'd change the calipers too so might as well go for this upgrade. Along with the SS lines. Planning for next week, will post an update after.
I am happy with my PowerStop rotors/calipers & SS lines on my '05 Yukon.....
( I was born in Victoria,,,, Moving to Palm Beach ...tomorrow ! )
TheAutumnWind
That is the best time to do it! Really does not cost anymore than simply replacing with the same original setup so why not go for a "free" OEM big brake kit?
AMM1986
